Hello! Sorry for bringing up old topic, but I have problem with my Zenith 28 IF and I don`t know what to do to solve it. First of all, carburator was cleaned, all gaskets are new, timing is set, all parts that have some role in igniton and driving are new, so I don`t have anything to replace anymore.
Problem is next- I found out that car is a little bit too slow (slower acceleration, lower max speed etc.) because I had a few R4 GTLs before it so I know how this car can drive. But car was running perfectly smooth, acceleration was a bit slow but linear, idle was constant.
Then I tried to set the mixture. I screw mixture to the end, and then unscrewd it for a turn and a half. Then I raised the rpm because engine was shaking. I could reach calm idle at about 1400 rpm which is way too high and if I set it lower the engine was shaking and turning off at breaking and releasing throttle. Then I unscrewd mixture for half of turn and then I reach calm idle at little lower (still way too high) rpm and then car was a little bit agile (prompt, faster, I`m not sure which is the right verb) but was still turning off while breaking and releasing throttle. I continued to do the same thing (unscrewing mixture, and lowering the idle) but only point where I could reach low idle (700-800 rpm) and perfectly calm engine is on 6th turn (6x360 degrees) mixture screw to the left which is, in my opinion way too rich mixture. On that setting car was like before- low idle, perfectly smooth and calm engine but slower.
I read everywhere that mixture screw has to be unscrewd between 1,5 and 3 turns for optimal mixture which is significantly less than in my case. I don`t understand what is going on here. My fuel consuption is relatively good (about 7 liters in town- around 40.3 mpg), car starts great, everything seems to be ok, but I realize the car is not agile as it should be on this setting.
Sorry for long post, I hope that somebody can help. Thank you very much!
