Today I did some rust/cavity protection on my chassis.
I used
Mike Sanders, a rust protection grease/fat that melts at 110 degrees Celsius and sprayed it into all hollow parts of the chassis.
For the first coating I turned the chassis upside down.
For the second layer I turned the chassis again.
I sputtered the full load of 2 kilogramme melted grease in the chassis.
Just enough to cover every bore and opening of the chassis from the inside out.
Here's a picture of the inside of the middle part of the frame...
Here's one of the rear frame.
Every Inch nicely covered with grease.
The chassis after some clean-up.
Tomorrow I try to mount the rear axle.
That will be an essential part of the work.
David
