malcolm
& Clementine the Cat
- Bedford UK
It's been 8 years since I last did any work on the Rodeo. I remember it being almost finished - work so far covered on https://www.renault4.co.uk/rodeo-mot.htm I've pulled the cover off again and it is still an odd looking thing.
The electrics were misbehaving which is why the instrument panel is out. There are a number of earth problems. The main body earth wire was routed into the cabin for some reason. I've relocated that to the traditional position at the front of the inner wheel arch. I'm not getting a good earth from the instrument cluster. Does anyone know where that earth connects to the body? Maybe through it's mountings. (Edit - it earths through the choke cable bracket and you need a temporary earth while the instrument panel is removed)
I've pulled the heater out to fit new hoses. It had been disconnected from the system probably because a hose failed but doesn't seem to be leaky. Don't know why I am bothering- it isn't going to do much with no roof.
Anyone know where to buy driveshafts for a 1972 car? They are different from the GTL and have a pin securing the connector at the gearbox end.
