That is a pretty dire repair isn't it? It reminds me of a dreadful bodge done to my Honda GL1000 motorcycle, one of the early "naked" GoldWings. One of the two bottom tubes of the frame is unboltable, presumably to allow an easier removal of the heavy flat-4 engine. This removable section can rust internally and badly. On this section is attached the sidestand. 600 lb motorcycle and corroded tube means this section eventually caves in. This must have happened to a previous owner (a PO) so it was welded up. Trouble is, the sidestand bracket was welded at the wrong angle so the bike leaned over at an extreme angle. Correct solution - fit a decent lower tube or weld the sidestand bracket in the correct position. What he did was to weld a 6" length of mild steel bar onto the end of the sidestand. Doh!
