reidalpine
I'm in the process of mating the new C2JP 7-13 1400cc R5TX-motor and R5GTL HA1 5-speed gearbox
together with the short bellhousing Also from a R5GTL before installing all into Roffen the F4.....
New motor is all complete with all outside stuff (dual carb/starter/alternator/petrol and waterpump,compl.clutch etc)
mounted the bellhousing to the gearbox and switched over from floor-stick to proper in-dash one,new
gaskets and seals all over- BUT....
Motor and gearbox came from 2 different sources, I found these separately.so never actually seen
them joined up...
Today when trying to mate them up (via R5GTL short bellhousing) something seems to hinder gearbox/bellhousing
going all the way into the motor ... I lack about 10mm to where they would close up and connect together..
Any ideas ???
-All mounting-holes and guidepins are in their right position and whre they're supposed to..
I had to leave the garage in a hurry to get home and start
to keep my sanity another day
so didn't count number of splines on primary shaft and into- and through clutch...
Could it be different? Could the primary shaft be different dia? different lenght?
ANY/ALL ideas would assist and support me from keeling over in a corner (too early) tonight.....
(In a case of overly self-confidence I'd already washed and ironed my beret to be right clad'for
some 4L-action this coming week-end
-Merde! -R.
them joined up...
Any ideas ???
