I decided to remove most parts as possible to clean them and have an engine as aesthetic as possible. This engine has about 200000 km, it works very well, the clutch has only about 30000 km, the engine oil have been checked up and all is OK, so only the external accessories will be removed. I want a perfect finishing for the engine, as good as the job still done on the chassis.
I only have few products and my drill to do the job:
Firstly I spray engine cleaner everywhere and wait for several minutes, then I rinse with hot water+washing-up liquid before final cleaning with acetone. It's really an awful job
but after several hours the engine is really better, it tooked me from 6 to 8 hours to finish the job:
All the parts removed which were painted like the cover, oil pan, timing gear cas, etc will be epoxy coated in black or in light grey for the pulleys.
The engine hardware and other differents parts will receive a chromate conversion coating:
All the new seals have been bought at Renault supplier:
And the exhaust system, here is the induction manifold, will be aluminium sprayed to protect it against rust, you can notice that the holes have been filled with wood sheets, bolts and nuts:
Before reassembinlg all these elements, the engine block and the gearbox are going to be painted in green, with a special paint, to have a "vintage" look
And when all this job will be done, normally my engine and gearbox should look like those of my Seven Replica which receive the same treatment in 2003 !
