Snoopy1974
The engine was not perfectly horizontaly hanged, so it was a little difficult to put it easily in the chassis:
But after few minutes of maxi stress the engine was finally fitted in the chassis
I decided to fit the water pump, to be sure that it will be water tight I decided to put the Loctite product on each side of the Renault seal, first on the water pump:
Then, on the seal after applying it on the water pump:
I don't have torque spanner, so when I fitted the water pump on the cylinder head I took care not to tighten the bolts too much:
Just a little picture of my rocker levers before fitting the valve cover, the manifold was fitted just after:
The valve cover was fitted with the fuel filter bracket:
It's late and I have to get up at 6, I think it will be VERY difficult
