progress has been fairly slow ordered 2.5 litres satin black synthetic chassis paint and got the roller back in action starting with rear axle next day it was dry but too glossy for my liking
Google suggested talcum powder would work mixed into paint but this was from a model making forum
Initial experiment with level teaspoon of Johnson finest baby powder stirred into small amount of white spirit ok and then stirred into 200 ml paint in an old ice cream tub this dried to a much less shiny finish
![20150529_183210.jpg 20150529_183210.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12623-d51215f4a5d37402e8fb3adb176abae5.jpg)
![20150529_183241.jpg 20150529_183241.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12624-f08e691adc7d55530eb229b03c094298.jpg)
The floor pan was given a coating of rubber stone chip sprayed on and once everything dry it was axle refit time
This was slightly more of a challenge than I thought and ideas of step by step photo guide went out of the window
As the chassis was lying on it's side lifting axle in was simple but the tension on bars means that getting all bolts to line up was not going to be easy
![20150530_162530.jpg 20150530_162530.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12627-b25c1594cf1f8cbb4de0c2ac7288e18b.jpg)
taking photos and trying to Lever things into place didn't really work so anyone attempting this must use this as a guide and work it out for themselvesI can only say starting with the two lower outer chassis mounts is a good idea
![20150530_164655.jpg 20150530_164655.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12629-aeec8b31eebc4c2a25ae7f2bf8d19de4.jpg)
![20150530_165222.jpg 20150530_165222.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12630-a3066cf79a9ad1c51ea87c49cd5d6137.jpg)
I can only add that an assistant was needed and I gave up and put the chassis flat to refit the remaining bolts I have left the outer slotted bolts loose until I can check the alignment much later on
![20150530_170648.jpg 20150530_170648.jpg](https://www.renault4.co.uk/forum/data/attachments/12/12631-e4486b2aecdc45fd69cd3ee13728afa6.jpg)
After about 30 mins I managed to work out by trial and error which bolts to fit first so can't recommend an exact sequence but would definitely recommend an assistant
Gave the floor pan a coat of paint and touched in a few marks from the axle
Next bit will be putting front suspension back together using some more nice new bits
