harbourseal
Renault R4 Lunatic
- Breda The Netherlands
As you can see the steering rack is still in its place. It must have been the downward way.
Hi. I have purchased wclough's R4 with the speedo not working, I have not taken apart yet but looking at these messages I need a new worm drive, are these available? There is a number cast into the o/s of the gearbox. 0001115600. kind regards SteveIt should be possible to remove the drive worm. I have no experience with doing that.
Since it is destroyed You might as wel give it a try. I don't think you'll do any damage to the axle it is attached to. If you try to pry it of.
Maybe some of the others on here have a spare drive worm for you. On the 20th Januari I can have a look in our club warehouse if they have one for you. But I need to know your gearbox number for that. The number is printed on a small disk on top of you gearbox.
Yes please, I also think I need the larger worm drive that is fixed to the gearbox shaft. Kind regards Steve, stevetildesley@gmail.comHi guys, today I went through my spare parts and came across a front gearbox plate with wormdrive & shaft. If you are interested I can make a photo of the parts to check. Let me know!
AndyThe identification tag was often put on the nearside front of the gearbox (see attached link), so it may be obscured by the radiator.
https://www.la4ldesylvie.fr/index.p...-354-hao&catid=20:boite-de-vitesse&Itemid=242
If it's an R1128, the chances are that it's an HA0-146 gearbox (see attached photo of the one on my GTL) - but it's absolutely essential to identify the gearbox type to ensure you get (if you can..) the right parts.
