That you have to pull out the choke a bit means that you do get a little to much air in to your engine. According to some engineers I know, this is a common problem with the Zenith 28 IF and modern unleaded fuel.
What helps is enlarging the main jet. Just take out one of the main jets from one of your other carburetors.
Take a 1mm drill bit and push it through the hole twisting it by hand. Do not attach it to a power drill.
From the top of my head the standard main jet is 0.9 mm by enlarging it to 1.0mm you get just a little bit more fuel in and that balances the mixture.
And shuddering should stop.
It's worth a try.
On both my F6 and the Sinpar I'm running 32mm solex SEIA carburetors I don't have the shuddering problems. A friend of mine dit the enlarging trick on his GTL with a Zenith 28 IF and that helped him. He barely uses the choke. Just to start the car.
Just a thought have you tested the connection of the manifold to the engine to?
Yes i have tested head, manifold joint, even tighten it little bit, but noting happened, and did not react on aerosol.
Will it make difference about you "new fuel" theory if i use lead additive for fuel.
Actually i put it every time i fill up fuel.
Also i use 95 octane unleaded fuel. Can that be reason for juddering
I have talked to few my local friends that drive R4 with zenith 28IF and they all have similar symptoms, except one. That one was working something with those levers that moves idle position when you pull choke
marked that lever on picture.
It looks to me like he just have done what i do when pull choke for few mm. But permanent
Try blocking off the pipe to the m/fold below carb ,that upsets the mixture ,i have blanked off a couple of engines including my own runs fine.
As harbourseal said your dwell is ok at 54 but it should not go to 59 ,could be a worn shaft bush.
So you are saying that my dizzy is worn to much?
Is there something i can do? Repair it!
Or i need to find one in better shape?
Or new one?
I had simillar problem as you - juddering around 60 - 70km/h on 4th gear when accelerate. It was worse with more loaded car. I did some inginition and carburetor setting and it didn't help. Then I changed sparks last week (I drove 25000km and run rich for some Solex32/ Zenith 32 testing time on them.) It seems to be OK now.
Well my spark plugs are old one used many years ago while car was running but they look OK.
Worth to change them.
Now i have Eyquem N43 bought in 04/2008 but have done some 20tkm with them.
I put them on car little bit more than year before i started to dismantle car.
And they worked fine on car before.
Any suggestion for spark plugs?
Petak, I can't help you with this one. But I can see the positive side of the problem, your hobby the last 6 years can still leave matters to investigate. I will stay tuned!
Well Borgeb there are many things still unknown to me about this small and simple car....that will end once.....i hope.... You help by just looking, reading, and listening all this staff.....it encourage me that at the end we will have one problem solved here at this fantastic place for R4 enthusiasts.
Something like this i can not find in Croatia
