Hi folks. I'm happy to report that the engine that I rebuilt over last winter has proven its worth this year with two trips to France, one of over 4000kms, without a moments trouble. I don't want to tempt fate, but I'm very pleased with how it's turned out, although I might have to replace the water pump, as it's just developed that usual suspicious noise, but no leaks.
I've now turned my attention to the back suspension as I've always thought the car rides a bit low at the back, especially when fully loaded with camping gear, so I took the plunge.
After removing the shock absorbers and eventually knocking out the torsion bars, lots of soaking with WD40 and a big hammer did the job, I then had the task of experimenting with the aid of an adjustable tool I made up, placed where the shock absorber usually goes. It's very much a case of trial and error, but I'm pleased with the results, as I've raised the back of the car by about 40mm. At least with the tool you can get some fine adjustment, and eventually line up the bar with the splines, but it takes a few attempts to get the height right and even both sides.
The hardest part was refitting the shockers as of course the mounting holes where now some 25-30mm closer together, so some serious compressing had to be done. Stout wire and cable ties did the trick.
I realise some of you will have done this job before, so I would be interested to hear your comments, but I now know that come the next trip fully loaded with all the usual paraphernalia of camping, my car will not look so low at the back. Regards Brian.
