AdamWilkes
- Poole
They only re-expand slowly, and the rounded shock end would only penetrate the ribcage a short distance, so all good.....
I might have to replace the water pump, as it's just developed that usual suspicious noise, but no leaks.QUOTE]
Hi Brian - hope all is well. What suspicious noises do you get with the water pump? I thought mine was on the way out as there was a leak but tightened a few hoses and seem better.The is a bit of a noise on idle but i thought it was the fan belt.
Hello BrianFunny you should say that Simon, that was next on the listGood to hear from you. Stay safe you two. Regards Brian.
