Fuel Injection Fault Problem
My renault clio dynamique s 1.4 cut out today was driving along came up on dash check injection tried to start car but wouldn't turn over made noise like battery was flat now says check esp
one of the first thing I would check if you get system-failure lamps lightening up is if the alternator/dynamo has died
Most newer cars shuts down various systems in sequence, and in the end you won't even get it to fire up again at all
-Not saying this is necessarily the fault with yours of course, but I've had that fault multiple times on fx a Ford C-Max
shitty car by the way-All electric componets says "Made in India" on it ,and looks to be made on that same beach where
old ships go to die! -Reid.
