Front Left Chassis Beam repair part 3
Continuing on where we left, the inner piece is ready and now we fit it in its cradle.
On the photo it looks "easy" but most of the time it was painstakingly measuring, fitting and alignment.
Tacked it in position and applying a weld thru primer.
The inner piece was build using 1mm sheet metal, for the outside parts I'm using 1,5mm sheet metal.
My farmers shed is not as well equipped as Petak used press brake and folding machine, so I'm limited on creating each outer piece seperately and welding it piece after piece.
Let's start creating the outside part on the outside.
Tacked it and plug welding takes over.
The bottom section is still open due to the famous R4 rust so the last plug welding can still easily be performed.
Final and grinding, the seam will be welded on a later moment,
Time for the outside piece on the inner side.
The outside piece on the top is next.
And finally a small strip to finish it off.
The seam on the outside is welded, grinded and zinced.
Unfortunately, as we speak winter has returned and the temperature is awful to work.
But fortunately, I keep you also busy in this way, on what's next.
Cheers, Joop
