Last days in 2021..
After recommendation I take of the shock absovers and put the new rubbers on it..
For someone who don't know anything of this, everything is a challenge.. put the anti-roll bar on the spot was very hard, Thanks to
@petak for all the tips!!
So after many tries without good results, I stopped and do some reflexion..
The measure of the holes are 12mm and the originals are 10mm, so let's swap it..
After some pushes.. something happens eheh
Gearbox oil refill.. 1.8l
Let's try but the wheels/steering straight..
Steering position on the "marks" with aprox. 71.5cm to each side.
Steering wheel aligned..
But I need to do some check on the Steering arm for passenger side, the wheel are too much open..
After this adjust I will try drive to a professional alignment workshop..
