"Maria Canela"
I think some of the camber we see in last picture is just an optic illusion. Shadow /dirt on the left tyre (seen from camera), and mobile phone camera lens.
I reacted directly like Malcolm. Something is wrong but I think camera and light fool my eye.
DAA I love your car and keep doing what you are doing.
Envy your climate, tonight we just got 10cm more snow here in Sweden.
  • Like
Reactions: DAA
Try rolling the car a couple of metres. The positive camber might just be because the car has been lowered from a jack.
For setting tracking measure the distance between the rear of the front wheel rims and then the front of the rims (inside edges while the car is on the ground). If the front measurement s maybe 1 or 2mm larger than the rear measurement then it'll be close to right.
@malcolm could you please explain better how to measure by this way?
I love my 4L too!! I'm very anxious too get our 1st big trip.. I try do my best..but I don't have much knowledge
Yes, Portugal have a lovely whether !! 10cm of snow..Ooh.. last night I got 4°c and I felt cold.. eheh
Knowledge will come. It is more important to have will to do it.
On other hand you can always ask somebody
That why i love this forum and keep coming back to it. There is always someone happy to share their knowledge with others
2000kms later.. I love my R4L!! Don't change it for another daily car..
Just need to check the washer of the carburator needle, because when arrives to the LOW capacity, smells a lot of gasoline and overflows out a little bit of the carb.
R4L's never says no!!!
Like I said in other post, with high temperatures, and stop on traffic, my 4L stop work and smells a little bit of petrol..
So I put the summer mode on the air filter box
Change the air filter cap, the upper cap on the photo have a curve tube.
And did some pending thinks..
Gearbox protection painting..and change the fix mode, for rivet nuts and inox screw
The handbrake cable support was broke the point of fix, I put a rivet nut too with a inox screw
I'm thinking do some thing to block the temperature from the exhaust manifold
Summer vacations on 4L.. without any incident
And after 6k kms, it was necessary do some gap adjustments
It's possible see the points too close at the highest position of the lobe
0.40mm distance....dwell angle on 58deg and 6degress BTC set.. and I have my 4L back again
I love this car...
Hello, great work! How will you block the exhaust temperature?
After 10k kms it's time to filters and oil change
The internal pipe of the final exausht silencer brokes, the sound of my 4L was like a race car ehehhe
I changed the final silencer for another one, old but in good condition and changed the slient rubber..
Keep on rolling.. waiting for free time to apply the twingo sunroof..
Preparation for annual inspection..10,892kms..
Twingo sunroof applied..
Hammerite paint for rust protection where was cutted
And put a kind of "silicone" which don't dry
And after a quick wash..
The green paper!!!
Preparation for summer vacations..
Towbar applied..
I need do some bumper restoration.. but until finish another car restore I don't have time and space..
Wiring to tow harness.
I choose split
Left:
Left switch and signalling light
Right
Right switch and stop light
Wiring protection
Next step do the same on the trailer 20230628_155701.jpg 20230628_155657.jpg 20230628_115925.jpg
31 years later.. the starter died..
So... get out the old.. and put the new one
I bought an not oem gasket and the quality is too poor.. I founded this original and the difference is huge!!!
Do this work is not too difficult
