Mike and I hauled the engine and gearbox out of the engine bay again so we could fit those stiffener brackets that go from the engine mounts to the bellhousing. This was a chore and I wish I'd known what they were before the engine went in the car. What's more, with brackets fitted it's nearly impossible to put the nut on the bottom of the driver's side engine mount because access is something that happens to other cars. Had to remove the bonnet, gear lever brace and steering column to get the engine and gearbox out as well as putting the lifting straps on in such a way that they cleared the locations we needed to fit the stiffener brackets. This was not a particularly fun job.
That done, a bit of info on the headlights. They are handed and have very specific fittings, not at all what I'm used to seeing.
On the outer side at the top there's a spring that the tab that makes the lights handed sits in.
On the inner side at the bottom is a clip of sorts that holds the bracket that doesn't have an adjuster in it.
Frustratingly, the two headlight mounting brackets are mirrored, which is why I can't use the spare headlights I've got in this hole.
So, I decided that I'd take the wire wheel to the passenger side bowl to see if it could be cleaned up to be repaired. Results were less than satisfactory and I stopped almost as soon as I'd started.
What I did notice is that the brackets that make these lights handed are just spot welded on. With care I can very likely remove them from the above bowl as they're in much better shape than the rest of the unit. I can them convert one of my spare drivers side headlights to a passenger side one. Since the brackets aren't fixed to the actual reflector bowl but the decorative surround I don't need to worry about damaging the silvering either as it shan't matter.
With that out the way I turned my attention to the ball joints. This was to be another horrible job. Started on the driver's side and learned by trial and error how best to remove the two rivets holding the ball joint in place. The third fastener was a captive bolt, the nut for which came undone surprisingly easily. After some effort with spinny tools and hammers, the old ball joint was off.
On fitting the new one, before I'd even finished tightening it, one of the bolts sheared.
Never mind, I found another suitable bolt and nut and had the lower ball joint all buttoned up and ready to go.
The upper ball joint put up more of a fight, this one has three rivets holding it in. I was thwarted in my attempt to fit the new ball joint because the upper collar I need to remove is also spot welded to the upper arm and to be honest I just hadn't the patience to deal with that. I had been at the unit at this point for six hours, much longer than intended, most of which was faffing about getting the engine in and out again. Here's one dead old upper ball joint.
In other news, I found and reinstated the factory jack. I'd hidden it under the back seat.
Got the gear linkage properly secured and fitted the throttle return spring. I think the throttle cable needs replacing, it's not only frayed but has a habit of sticking when you've pressed the pedal down because the cable doesn't move smoothly in the sheath. I also fitted the two tiny pieces of new fuel hose needed, I just haven't put clamps on yet as I couldn't find them.
Can anyone tell me what this is and where it goes? With it sat on top of the air filter the wire is pretty much at maximum extension so I assume it must go on or near the carburettor, I just can't find anywhere it looks to fit. Seems to be some sort of sensor.
Tried out the seating position properly today and the gear change. I like the latter but not so much the former, the pedals and steering wheel are very offset which has caused me problems with cars in the past. I might get on with it, I might not, I shan't be driving the car enough for it to cause me the problems the Maestro did.
The only thing that's jammed on the dashboard is what I assume is the heater control which is stuck on RED. I haven't attempted to force it for fear of breaking it, it's jammed so firmly it's like it's been bolted down. The choke pull works, it could just do with a little fresh grease to make it smoother to operate.
