petak
- Vodice, Croatia
After a while story on R4 goes on
It is time to set interior of the car.
Roof lining was obvious first job to do while there is no seats inside to get in the way.
At the start i would like to warn you about one detail that i have learn on hard way.
Bars inside roof lining that holds it tight are not the same and every one has its special position.
So be careful when you take them out to mark their position.
I have put half roof lining in place and find out that bars are in wrong places and i had to remove it from car, change bar position and start all over again.
Which one to use?
From this far away they both are perfect, but closer look tels me that one of them is torn in few places.
Choose better one of course
End plugs of the bars (2 are missing on picture)
First bar in position
Everything is hanging around
Second bar in position
Left view
Right view
I have begun on booth side because on front you have wooden frame that is screwed into roof, and this way seems to me more easier
Start is difficult because you need to catch roof lining with channel in roof made for it.
And to do that you need to use rubber hammer and easily tap that roof groove, but problem is that you have only two hands.
But somehow it is doable. After that it goes pretty easily.
But you need to be careful as groove is sharp and can torn roof lining easy.
Which one to use?
Left view
Right view
