Vulgalour
- UK
I am stumped so I'm posting this info on all the forums I use for this car. This is going to be a simple fix but one that I can't figure out, I've just ended up confusing myself.
In the book it states there is a V mark on each of the sprockets the chain goes on. My engine does not have these Vs or if it does they are so feint as to be essentially invisible. Here is the helpful diagram (which is printed upside down for some reason)
Now, when I first timed this I did it to "the timing marks" as directed by the Haynes and got it wrong because I lined it up to the two marks I do have on the sprockets that being a dimple on the camshaft and a blob on the crank, as below. The crank is at tdc when the blob is at the 10 o'clock position, piston nearest the timing chain is at the top when the blob is at 2 o'clock and at the bottom when it's at 8 o'clock.
If you line up as per the book instructions, taking the blob/dimple to be an alternative to the V marking, you cannot get a full revolution of the engine, presumably because a valve is touching a piston or something, I don't know. I wasn't inclined to force it, I'm being very gently gently in my approach. An internet hunt was futile, I could find info on how to time jet engines and ECU remaps but couldn't find anything to help me with this, I just ended up even more confused.
So now I'm cold and frustrated both with the job and myself.
