R4 TL restauration
Very sound advice, the pistons look perfect. Just clean out the ring grooves very well before you put the new rings in.
Hi Guys!
Sunday, well - it was a bit of a lazy day.. I organised my toolbox and I cleaned the workshop :whistle:
I also did some smal thingies:
-sandblasting & painting the supportbracket for the carburator
-cleaning the front innerwing. Those were swedisch, so i had a 1 cm thick protection layer on it. Took me 2 hours to clean! (one more to go...)
-some 'pre-assembling' on the cilinderhead
WP_20160805_14_51_28_Pro.jpg WP_20160805_15_29_59_Pro.jpg WP_20160807_14_35_23_Pro.jpg WP_20160807_15_24_20_Pro.jpg WP_20160807_15_46_51_Pro.jpg WP_20160904_17_53_48_Pro.jpg
This week is my last week of the summerholiday, dammit...:doh:
:drunk:
Ha ha I know that feeling. Getting some quality time in the garage with your R4 is difficult! There is ALWAYS something or somebody determined to shorten your time
Haha, so true Jonathan!
Today I have been working on the steering mechanism. I find the cause why rotating was so hard.
missing splines.JPG WP_20160805_14_51_28_Pro.jpg WP_20160808_09_57_09_Pro.jpg WP_20160808_09_57_13_Pro.jpg WP_20160808_10_50_32_Pro.jpg WP_20160808_10_50_42_Pro.jpg WP_20160808_12_53_59_Pro.jpg WP_20160808_13_27_29_Pro.jpg
This afternoon I went to another engineshop. What a difference! I was helped very friendly and the mechanic also checked the pistons & rings. Worn out to the bone.. He will polish the bearing areas (don't know correct word) on the crankshaft (it has some tiny scratches) and he will measure them so I can order the right bearings.
Funny, he was restoring a Mustung '67 and the owner of the company a 4CV. We had a pleasant talk!
Question:
I placed the front shock absorbers, is it correct I can't bolt them on the top due to the unloaded chassis? I'm not sure if the height is correct now.. Any advice? I didn't measure the distance from ground to floor when only the chassis was left... Lesson learned..
cheers!
Harder to fit shocks as ther is no weight to stop the body lifting as you put a jack under lower arm
Assuming torsion bars refitted as original some helpers sitting on front of chassis wiil let you get top.nut in place
Don't worry about height until whole car all back together
Looking at steering bearing is the pinion shaft ok ?
Hi Paul,
Oke, no worries until full car is back together.
The pinion shaft has some tear and wear, but is not that serious damaged, I think. I will make a photo tomorrow.
Yes! I received the engineparts!
To be continued soon
Good and bad news,
Me - stupid - ordered the wrong liner en piston set. I found out that:
So, when ordering new pistons, check gudgeon pin diameter!
Pressing the gear back on the camshaft..
WP_20160903_17_45_45_Pro.jpg WP_20160904_16_49_46_Pro.jpg WP_20160904_17_33_13_Pro.jpg WP_20160904_17_33_19_Pro.jpg
Good news, crankshaft alive and kicking!
So to be continued..
Think it was discussed recently about how far to press sprocket on as there needs to be a small amount of end float
Hopefully your supplier will swap piston for correct type
Thought the engine code would identify them
I've got 3 with the 14 mm pin same as dauphine
Hi guys!
I have some updates to share. The engine work is a very slow progress. I brought the liners & pistons to an engineshop for installment on the conrods. Unfortunately thay made a mistake with one piston, aaargh. I brought it back so they attach it the correct way.
WP_20161014_11_03_02_Pro.jpg WP_20161014_12_11_04_Pro.jpg WP_20161015_16_04_11_Pro.jpg WP_20161015_16_04_23_Pro.jpg WP_20161015_17_00_08_Pro.jpg WP_20161030_15_08_59_Pro.jpg WP_20161030_15_26_54_Pro.jpg WP_20161030_15_28_18_Pro.jpg WP_20161030_15_45_42_Pro.jpg WP_20161030_16_01_15_Pro.jpg
Cleaning & painting the radiator
WP_20161016_13_35_50_Pro.jpg WP_20161016_13_35_59_Pro.jpg WP_20161016_14_55_50_Pro.jpg WP_20161016_16_47_28_Pro.jpg WP_20161016_16_47_35_Pro.jpg
Hello Jurjenz your radiator looks like new again, but have you had it pressure tested or perhaps filled it with water to check for leaks? I spent a few hours cleaning mine and only after I fitted it did I discover that it leaked badly:(. So I ended up buying a new one.
The blockage in the little tube on your manifold is oil from the fumes from your rocker cover. If it stayed blocked, then the fumes would be sucked into the top of your carburetor and cause an oily mess inside. There should be a restrictor pipe in the rubber hose that leads to that little pipe. The restrictor has a 1,30mm hole in it to let the fumes through.
My engine actually ran better when the pipe was blocked, so I made my own restrictor with a 1,00mm hole in it and it now runs better.
Beautiful set of pistons!!
Jurjenz this is fabulous work thanks for sharing with us. I found the forum a great way to keep my motivation up.
Keeping the workshop tidy helps too. ( not something I would be good at normally )
Hi!
I did not test the radiator. I presume it has has no leaks because when I drained the cooling system clean water came out. The engine had not run for two years. So I hope it is still good!
:whistle:
Working on main brake cilinder
WP_20161018_12_38_09_Pro.jpg WP_20161111_12_27_21_Pro.jpg WP_20161111_12_37_05_Pro.jpg WP_20161111_14_53_15_Pro.jpg WP_20161111_16_08_36_Pro.jpg WP_20161111_16_08_43_Pro.jpg
